Hydrostatic fluid
red2blue
Noob here looking for an answer to a question.
I recently changed the drive belt on a Statesman 16.5/42". Lemme tell ya...what a chore. Glad this belt will prolly be this mower's last Kevlar.
Anyway....the transmission whines...not bad...but going back to my old automotive days...it sounds like a power steering pump in my old T-bird after it leaked out a bunch of fluid.
Now my mower don't leak....but I feel...have nothing to go buy....just a feeling...that it should have more power.
How do I check the fluid level..and if it's low...what kinda fluid goes in? model# 13AN694G016
Thanks for your time.
gfp55
You can download a manual from 301 Moved Permanently then put in your model# seriel #.. The manual says that you should not have to add fluid and doesn't require checking. If you need service go to a dealer.. The hydro holds 2.5 quarts SAE 20W50
