hydrolic problem
rottyx22
xf 2500 quad loop . My right side pump blew so I replaced it with a new one now when I try go forward and back it feels like it is binding and not turning the wheel. I took the wheel motor apart and found metal shavings. I cleaned the motor and put it back together and still the same thing. the pump is trying to move it and is staining forward and back and the wheel moved a tiny bit but still nothing. any idea's. thanks
Sounds like the pump has failed and is damaged. Be very careful about running it like that because the damaged pump will send shrapnel into your new wheel motor and damage it requiring it to be repaired or placed again.
