should be able; though, depending on placement you need to remove the pump. The SM says disassemble the pump but I am pretty sure you just remove the check valve assembly. Also note the replacement may look different as it has been updated so if your pump has the updated one it is a wrench instead of a hex wrench for removal.
One thing of note check the bypass valve o-rings as they harden and start to leak. Just had to do a partial pump on a Super Z a couple weeks ago because of this.
Also if you remove the charge pump cover watch out the steel ball and spring as they can get lost easily. One other thing on the charge pump cover they used 5/16 Hex Screws (1/2 hex), may find hard to get off and then if you can go back with 5/16-18 x 1 - 12 point screws. Much easier to install and torque. Replace the o-ring if cover is removed.
