HI hope someone can help. I bought a pump very cheaply from Ebay which is NOS. I buggered up as i need a pump that runs CW and this one runs CCW. It also has auxilliary pump attached on top of the charge pump. Now ive always been under the impression if you rotate the charge pump 180 degrees it changes the input rotation of the pump. I have contacted Hydro Gear and they won't help. Now the pump I have is a BDP-10A-903. a CCW pump. While searching a BDP-10-703 has every part the same housing/charge pump etc and it runs CW. I have rotated the charge pump and fine on flat ground and wont go up hill and creates heat. I turned then the auxilliary pump 180 degrees to match the charge pump turn so both are now turned 180 degrees from original. Pump creates heat like in 15 seconds. Any idea on a fix.
