Hyd Problem
bus
Have a xxw4000 S N 7915112 Been sitting for 1 year twin engine run ok. Machine run ok on level ground but stalls on small incline One pump a little warmer then the other Can you check any pump pressure at any test ports Any one had small problem and what did you discover Has any got any ideas where to start
Explain your problems exactly and include a model number if you want help. Do not say it is just like the OP. Explain in detail what it is doing.
