Hustler Super Z Wheel Hub removal
squalls30
Here are the symptoms I'm having.
Left wheel will not move forward or backwards. It won't move with the relief valve open. I removed the wheel and the large nut on the hub and placed the puller on the lug studs. I tightened it down with a breaker bar and hit it with all types of hammers including a giant sledge hammer. The hub hasn't moved a millimeter. I've sprayed several penetrating oils and it's soaked for over 60 hours now and it still will not come off. I'm thinking there is something that is sheered internally that is holding the hub. Is there any ideas that you may have to help resolve this issue? I have the parking brake released.
Hope you got it sorted but I wonder if it was the woodruff key getting jammed up?
