Hustler Super Z pump problem ?
cjcall
Hi Everyone,
My Name is CJ and I'm new to the forum. I have a Hustler Super Z. I have a distinct noise ( a screeching sound ) coming from the left side hydraulic pump when left handlebar is put under a load. This does not effect the mower operation but sounds real bad.
Need help in diagnosing the problem. I suspect that I need a new pump even though the mower was bought in 05 and only has 400 hours on it.
Thanks in advance for any help you might provide. C.J.
chance123
Are your belts tight? If it was a "wining" sound That would be your pump.
