mowing4me
- Aug 25, 2021
- 2
- 10
I was out mowing today and as I was making a pass I suddenly notice I no longer have any forward or reverse on Left Side Drive. I see no signs of burst lines, Fluid reservoir is full. Drive belt must be intact or else RS would not work. From what I have looked up it could be the wheel motor or the Hydro-Gear pump. Any Hydraulic specialists out there that can give me a what to check first list. Once I can get it back in the driveway I will jack it up and test if there is anything flowing that will allow the wheel to turn under no load.
Thanks in advance
Thanks in advance
