Hustler Super Z 66
Broncoc
Just bought a Super Z (older Model) to help with my field that I mow. Guy broke axle on left side, had it welded back and sure they went bout it all wrong. My ? is if it has a leak in left side will it affect the rest of the system? It is slow, don't climb hills good, slow response all together. I thinking in hyd or maybe motor weak. mower has a v twin kolher 30 hp. Changing left wheel motor if I can find problem with few other things that gonna check into this week. Thanks, Broncoc
MRCo.
If there's a leak then air and dirt can get in the system and spread the contamination. Check the wheel motors- if they were made by White then they are known to be problematic. They are about $450 each if memory serves. A kit to fit Parker motors is available, but you lose some ground speed.
Broncoc
well it not leaking or anything, I know they ended up taking wheel motor apart to weld shaft back on, looks like good job on welding but not sure if it would affect other side. gonna try check engine rpm and governor and make sure they working correctly. Thanks
