Cut my yard for the 2nd time today with my 42 inch sport. Excellent cut in quick fashion. Decided to go ahead and change the oil (recommended for an initial change at 4 hours). Now I have my first beef with the unit. Mine has the 17.5 Hp B/S engine. Not sure that it makes any difference since the owners manual for the unit is universal although I have a separate engine manual.
Anyway the means provided to drain the oil is as described in the owners manual, slightly different than the B/S manual. What is provided is a flimsy 'quick open so called valve' and an eight inch piece of tubing. The tubing is necessary because the drain valve is located probably 4 inches from the edge of the steel engine deck. Unfortunately it takes virtually the whole eight inches to extend the drain off the edge since you have to bend the tube to get it behind the tire. After removing the dust cap, and fitting the tube to the nipple, you are to turn the plastic valve to the left and pull it straight out to initiate oil flow through the valve and nipple. Mine was so flimsy that it slid off the metal fitting, spurting oil everywhere. After shoving it back on and having to refit the tube while oil is coming out, since the tube being so bent to extend to a drain position was not happy about having the connection on the other end turned/moved and decided to come off. Eventually the unit drained, with a cup or so laying on the deck and in the 3/16 inch wide gap between the engine and the frame behind the seat. After mopping up the bulk of the oil and being amazed that anyone could engineer an oil drain system 1000X worse than the one I had on my Dixon that I often had unpleasant thoughts about, I proceeded to examine the 'valve'. I found it cracked. Not that I placed any unusual force on it. I seriously doubt that anyone actually could be expected to successfully use the drain system provided on a routine basis, (I'll allow that you might get lucky once). Perhaps I'm overlooking something major other than what was provided. Anyway, have any sport owners come up with a better valve/drain system? I thought I'd ask before heading back to the dealer.
Carl53 I just bought a used Fastrack that has a new GVX 630 Honda on it. After reading your post about the oil drain I went out and checked mine. The oil drain is right over the frame. There is NO way to drain the oil with out making a BIG mess. Im going to call the dealer that I got it from and see if he has a solution. If not I have a deal that I can suck the oil out with. Then when I pull the filter it should get the rest of it. Poor planing on someones part.
I have owned my Hustler Sport for 2 years now. It's the 42" deck, Honda GXV 530 configuration. My lawn is a challenging 2 acres of rolling hills and obstacles which includes a 60' long 15 degree slope in the front that is over 250' across. My prior mower was a Scag 48" walk behind with a 17HP Kawasaki.
I choose the Hustler Sport for it's build quality and compact design. The frame, deck, blade speed and components are are a step up from the more popular residential choices in this class. The Scaq Freedom is a quality machine but I simply had no place to store it. Same for the Exmark Quest.
The Sport's low center of gravity is a big advantage. It's extremely manuverable and stable. Cut quality is as good as my Scag. At my time of purchase, the Kawasaki was not an option ... but I have been impressed by the Honda's performance and would buy the same configuration again today. It's smooth, fast, is never bogged down by tall wet grass, and powers up the hills.
There has been alot writen about zero turns and hills, so here's my experience. The hill in front of my house is an extra challenge because it faces south. It's also has a concave curve in the center. So it's 15 degrees overall, and about 18 degrees at the steepest point. Both the top and bottom are flat. The grass can easily be burned out by the sun by mid summer if you attempt to always mow in the same direction. Heavier commercial riders would destroy the grass on this hill.
The recommended cut is across the hill. The Sport can cover this 250' run without slipping, although in the steepest section I'm pushing hard on the foot rests and leaning into the hill to avoid sliding on the seat. Cutting straight up and down the hill is actually easier... and I know, not recommended. The flat areas on the top and bottom of my hill and Sport's low center of gravity make this possible. The Sport acceleration up the hill is stable and impressive. The trip down the hill is more of a challenge. You need to start slow and go down no more than 10 degrees off center. Beyond that point, the Hydros can release. In my case, with the flat area at the bottom, it's not an issue. To keep sun related damage on the hill to a minimum, I vary direction every cut.
I highly recommend the Sport. If you have an application with a hill steeper than mine, you should consider a model with the heavier duty hydros. The Hustler FasTrac uses the ZT-3100s which have 50% more wheel torque.
Hey there,
Wanted to get some experienced feedback from member's on the Hustler Sport:
- Does it cut well?
- How is the mulching kit?
- How does it do with the bagging kit?
- Is the motor strong enough to get wet grass into the bags?
- Does it mow fast?
Anyother thoughts greatly appreciated.
Thank you!
Tim
Hi, I have owned a Hustler Sport 48" for about 2 years now. I like the size of it, and the heavy construction of the deck, the heavy-gauge blades, and the high blade tip speed, etc. I am happy I did not buy a larger machine, as I think it would not have been as easy to get around in my yard.
I have the 21 HP B&S engine, and it has been problem free, until, ahem, now.When I started it to move it and change the blades yesterday, it ran with low power etc and would not crank over, like it had high compression.I did some research and learned the stud for the intake rocker arm comes loose sometimes, so I looked and mine was very loose; this was easy to fix. However, the engine still has something very wrong with it, and I may have to buy a new one.
The traction of the rear tires is a little less than I would like sometimes; this may be because of the type of tire tread. I can mow on a slope carefully; if you ever cause the rear wheels to slip, you are pretty-much out of control and sliding to the bottom of the slope or ditch. If I put too much air pressure in the rear tires, it really reduces the traction.
I wish a starter cord would be included with these engines; if you have battery trouble you are dead in the water, and you can't push or roll it as far as I can tell.
For the price I don't think you will be unhappy with the Hustler Sport series.
Hey there,
- Does it cut well?
- Does it mow fast?
Thank you!
Tim
