Hustler Raptor SD Will Not Move
Dirtboy6
I cut for about 5 minutes went inside came back to finish and my mower will not move. I looked at the hydraulic reservoir and it appears to be half full. What could it be?
Thanks
Kevin
As the last poster stated check the drive belt. I have seen a few of these mowers have the issue of transmission bolts coming loose and it throws the belt. If still under warranty take it to the closest Hustler dealer.
