Hustler New Front Tyres
Skippydiesel
I am about to replace my Super Z front tyres (13 x 6.50-6).
I have found Kenda K404 Smooth (no tread) tyres similar to the origional.
Can't say I have had any more than the usual problems with the OM's, but like the "look" of tyres with tread better.
Do smooth get more or less punctures than treaded tyres??
I will appreciate your feed back on smooth V tread tyres, for this zero tern mower.
:devilish:
Hi S.,
Have you considered solid airless tires already mounted on the rims? They are making them now for many models. You will need your spindle width and axle diameter measurement in addition to the tire size.
Thanks Auto Doc's - Yes and decided against solids & semi solids.
My mowers, much like my tractor and skid steer, depend of the flex/give in the pneumatic tyres for a small amount of ride comfort. Solids will take that away and make the ride just that little bit harsher (hard on my antient back/posterior).
Will go with pneumatic however undecided about smoot/treaded
What say you?
:devilish:
What say you?
:devilish:
Smooth tires.
Solid tires-no air.
Suspension seat for greatly improved ride quality.
Many new zero turns mowers are coming with solid front tires. The ride quality of front tires with air versus solid tires is not much. However, a regular seat versus a suspension seat, is a total game changer. Do yourself and your neck and back a huge favor, and install an aftermarket suspension seat!!
Not much difference between smooth and rib/threaded. It just the rib/threaded provide better traction that front wheel steering which ZTRs don't have. They also provide wear indicator. As flats I have not seen much difference in ratio of flats on smooth vs rib/threaded. All tubeless tires get punctures. Here it is Bradford Pear tree thorns the main cause which why I have to check tires very close before installing tubes.
Those tires are not completely solid but very thick. I just installed some CarlStar Reliance tires.
Here's the difference I find those semi solids are like the Michelin X Tweel spokes tires on JD. Now the so called solids are actually hollow if they are the CarlStar Reliance tires but they are one to two inches thick. And they do provide a rough ride which the owner was running lower rear tire pressures.
These Reliance are a real pain to change out. First the old ones must be cut off and the rims cleaned of rust. The installation is straight forward provided you have the right equipment. So in my case it is a hydraulic press, a hydraulic jack, a mounting cone, and two sets square layout 4x4 spacers. IE the spacers are assembled in a square pattern with in the case these 6" rims with an opening of 7-7.5 inches [depends on the cone max width]. Then the tire and cone are heavily lubed up Silicone base lube then you start pressing the tire onto the rim. Not a job for an individual for one or two time deal. On the JD Z950 I charged $132 a piece for the 13x6.50-6 including mounting and new bearings. Not to bad for the customer as the Rotary 16659 were listed at $220 each for all new tire and wheel assemblies.
And I got down the booting of the tubeless tires. Lawnmower tire requires are different cleaner than the one I was provided to do the job. But no buffing that might penetrate the inner liner needed. And CarlStar was of no help on finding what would work either. They said just use the stuff from the local hardware store.
