Hustler mini zee no start problem
Radioman
Hello Everyone, I recently joined and a couple weeks ago I was asking for help with a no start problem.
I became frustrated after a few people posted to my thread because I was having no luck diagnosing my problem even with their suggestions.
I stopped communicating but I kept reading and studying YouTube related videos.
I finally solved my problem and I thought I would share it in case someone else finds it useful.
I had no spark
I pulled kill/ground wires off of coils
At that point I regained spark, which meant the issue was in the wiring harness, safety switches, or relays.
I traced wire from ground/ kill on coils back to the run relay and checked continuity which was good and no shorts in wires.
I removed run relay from socket and it looked corroded.
I had a hustler supplied run relay on hand and plugged it in and turned key switch and it started up.
Finally problem is solved.
