Hustler Hydro Gear Installation
daveh1959
I am replacing the right side Hydro Gear pump/motor on my Hustler Z-Trac. I have purchased the new unit but the break gear/locking lever is on the opposite side from the old one. apparently this is the way the new ones come now. Has anyone else run into this issue? Is there a retrofit kit or part available to get the break linkage hooked up to these newer units?
Thanks!
Dave,
That doesn't sound correct at all. Call the supplier, ask them to replace it with the correct installation product. Be adamant if necessary, also be polite.
Max
