Hustler fastrak
dtl
Hello everyone, I was wanting a little help on my hustler fastrak 54" mower. I bought it this spring and it has worked great until today. The right side steering arm got real loose, then when I put it in reverse, it stayed there. I can pry it to the neutral position, but that's it. I looked at all the linkage and it all looks good. Any ideas would be greatly appreciated!! Thanks, Don
gabowman
I was messing around Hustler's website last night and saw where you can download maintenance and repair manuals for your particular mower. Look here at the bottom of the page and download the manual. If the mower is less than a year old I'd let the warranty fix it but if it's older you may try this first. Maybe this helps you some...
Hustler Turf Products - Residential Mowers - FasTrak
