Export thread
Hustler Fastrak Z 52"
#1
G
grad
I have a problem with the transmissions and their bypass valves. The rod on the left transmission does not seem to reach the connection point for its bypass valve. Also the right transmission loses power after running for around an hour of mowing. Is the right transmission just going out or could it be a problem with the bypass valve not engaging properly?
