Export thread
Hustler FasTrak SD 54" Zero-turn
#1
S
Sherryd
Help, we have had our Hustler for years, with over 200 hours on it. Today, while mowing at in-laws it died three times. 1st time - out of gas, easy fix. 2nd and 3rd time - started back up after cooling off. So I loaded it up and hauled it home. Any idea what happened, and how I can prevent it again?
Sherry
#2
RhettWS
RhettWS
Change the fuel filter. At least that is where I would start. If you ran all the gas it it probably sucked in some trash. There are others who will likely chime in with many more options than I.
Good luck.
