Hustler Fastrac fluid capacity
merc525
Hi Guys, new here to the forum and looking for some help. I recently aquired a Hustler Fastrac zero turn, model 927459, with a 52" deck. my rear axle seal failed and fluid leaked out. I replaced the seal and bearing but cannot find the amount of oil to refill the transaxle with. I downloaded an owners manual but it refers me to a dipstick to check the fluid level but I cannot find a dipstick. any help would be greatly appreciated as my lawn is turning into a hay field
BlazNT
First go here and download your manual for your drives.
http://www.hydro-gear.com/332a7c5827_sites/hydro-gear.com/files/BLN-51134_P5.pdf
20W-50 engine oil @ 79 fl. oz. (2336 ml.)
To purge air from the system.
Purging Air from Hydraulics
1. Raise rear wheels off ground. Brace with jack stands.
2. Put bypass valves so it freewheels.
3. Get on mower start it and release the brake.
4. Push drive lever full forward for 10 seconds the full reverse for 10 sec. Do this 10 times for forward and 10 times for reverse alternating between each.
5. Return levers to the parked position and set brake. Turn off the mower. Move bypass valve bake to normal operation.
6. Get back on the mower and start it. Do step #4 again.
7. Return levers to the parked position and set brake. Turn off the mower.
8. Return mower to ground.
9. Test for proper working. If not repeat.
10. Check oil level and fill.
