I have a Hustler Fasttrack zero turn mower with 20 HP Honda motor. It starts and runs great except if you run it awhile and turn it off. If you try to restart it just cranks and will backfire. If you let it completely cool off it starts right up. I have replaced both coils, the wiring, seat switch, the starter switch, blade switch & some relays and it still does it. Does anyone know what it might be? It has been doing this for the past two summers.
