Export thread
Huster 262 Belt Routing
#1
J
JamesDorr
Hi. I blew a belt on my Hustler 262 Model 923474. I've searched the Hustler site, no manuals. I did find a parts manual, but what I need is the routing diagram for the belt that runs the deck drive.
I've also searched this forum to no avail.
Any help is appreciated.
#2
R
rick.kinney
THEIR IS A DIAGRGAM STICKER ON THE FRONT OF THE MOWER DECK. FROM THE FRONT PUT A LOOP IN THE BELT AND SLIDE IT IN FROM THE FRONT OF THE DECK, THEN
WRAP IT AROUND THE FIRST PULLEY ON THE RIGHT "THE OUTSIDE OF THE BELT " THEN GO AROUND THE RIGHT OUTSIDE PULLEY WITH THE INSIDE OF THE BELT, NOW PUT
THE OUTSIDE OF THE BELT AROUND THE INSIDE OF THE TENSION PULLY AND STRAIGHT BACK TO THE MOTOR PULLY WITH THE INSIDE OF THE BELT. PUT THE LEFT SIDE
OF THE OUTER BELT AROUND THE BACK LEFT PULLY THEN THE INSIDE OF THE BELT AROUND THE FAR LEFT PULLY THEN THE OUTSIDE OF THE BELT BACK TO THE FRONT LEFT PULLY THEN PULL THE TENSION PULLY CHAIN/ SPRING TIGHT.
#3
The Chairman
The Chairman
I googled it and found two possibilities
This one matches my SD Raptor 60" and this sticker is on the bottom of my seat:
And there is this one:
#4
M
mechanic mark
