Husqvarna YTH2348 does not start
gmeeper
When we turn the key, nothing happens. No sounds, nothing. Have checked the battery and 20A fuse and both are good. Checked the air filter which is clean. Full tank of gas and oil. Can anyone help, please??
066
Check that the blade engage switch is in the OFF position, make sure the safety switch on the brake/clutch pedal is connected & hasn't fallen out of position, if the switch button does not get pressed down all the way, the engine wont start.
Flyin2low
Time for a new PTO switch diode.
gmeeper
Thanks all for the suggestions and ideas, but after some testing we had figured out that the solenoid had gone bad. After picking up a new one from HD for about $15 and spending about 10 minutes, it works like new.
