My Husqvarna YTH2148 front wheels are toed out and there is no adjustment. Thinking of putting wheel linkage (rod tie) in a vice and straightening some. But I have an additional problem. Belt clutch below the motor has been eating into the wheel linkage as it swivels underneath. Fairly bad. Mower is about 14 years old and was worked on once by a shop. Years ago. They probably removed the link and I now question if they put it on back right. Is there a left and right to the link? I reversed and it seems better. Still have toe out problem. Any suggestions?
