pburlison6
- Nov 11, 2013
- 3
- 6
I purchased a Husqvarna yth2148 with a 21hp Briggs and Stratton engine on it.
The previous owner had taken the heads off. He didn't put anything back together. I have all the parts and I'm pretty sure that I have them mounted correctly with the exception of a bracket on the left side. The headlight cable is strapped to it and it has 2 mounting holes and a large hole on it. The bracket is L shaped. If anyone can show me a picture of this bracket mounted I would appreciate it. While your at it I would like to see pictures of the front and right side to be sure I have them right. The year is 0404. The model , type and code is 385777-0349-E1. Also on the back of the motor their is a similar bracket with a large hole in it. I think the throttle and choke cables have been replaced. Do the cables go through this hole?
