Husqvarna YTH 150 ; SERIAL: 092498B 001377
MFG ID Number: 954140007H ; Product Number: 954-14-00-07
Engine: 15 HP KOHLER ; MODEL NUMBER: CV15S
Request Assistance:
Just Replaced the Drive Belt. Tried to crank the engine before I reconnected the deck
just to make sure I had the Drive Belt on correctly. When I turned the Key in the ignition
all I hear is one single click. Starter will turn over. Battery & Terminals is good.
What do I replace ? Starter or Ignition switch ---- or both ?
Many Thanks,
Mike Satterfield
#2
tom3
The click would tell me that the key switch is probably ok. If all the wiring looks good with clean connecors I'd get a new solenoid or a starter
