Husqvarna XT722FE
Adamj19
Have you guys or gals have had any problems with the kohler courage xt-7 engines. I recently took it into my into a repair shop and they diagnosed that it would not start was because of the auto choke, they ordered a part kit for it they had installed it then got a phone call saying what they had diagnosed was wrong and that the sparkplug was threaded wrong out by 1/2 inch. How do I know if they had done this? If they diagnosed the engine would they look at the whole engine for just a specific area. Can you guys please give me some good answers please. This unit is 2 years olds.
Kohler has had some issues with select XT-7 engine for no start due to a problem with the auto choke mechanism. The spark plug problem could of be found when they removed the blower housing to install the choke kit. The spark plug is not very visible with the blower housing on and would not of been readily visible. If the spark plug was not threaded all the way in for some reason that could also cause a no start or hard start situation.
Adamj19
Do you think the repair place could have cross-threaded the plug? The only reason im saying that is it started with a little help but now it does not start at all.
SONOFADOCKER
If you didn't touch the spark plug .... Then the shop did the damage .
Did the mower start correctly when new. There is no way of knowing if the repair shop damaged the spark plug threads if they don't admit it. I can tell you that where the spark plug is located on that engine cross threading the spark plug could be done very easily because it fits about 2 inches down inside of a blind hole.
Adamj19
It started before i brought it into the shop but wont start now.
SanAntonioJoe
Hello, just joined this forum and wanted to give my feedback on the Husqvarna XT722FE that I have owned for four years. I'm in the San Antonio, Texas area, and the weather here can be warm year round, which is closely related to my experiences with this mower.
First and foremost, if you are in a warm climate and thinking of purchasing a Husqvarna XT722FE or any brand with the Kohler engine, make sure it DOES NOT have the automatic choke. They DON'T work properly in warm climates. I purchased one of these, and the bottom line is, my local factory-authorized repair shop had to work on it twice, finally replacing the carb assembly with a completly different unit with a manual primer bulb. The factory rep finally told my repair shop that those automatic chokes were causing them a lot of problems, and it shouldn't have been sold in the warm Texas climate. Problem is, once the engine starts, it never cools off enough to engage the automatic choke again. The mower will start fine first thing in the morning, but for the rest of the day you will have major problems getting it to restart. And, if the mower is sitting in the sun, even if the engine is stone cold, the automatic choke won't engage at all because the radiant heat of the sun will trick the automatic choke into remaining open all the time.
I purchased this mower in April 2009, after giving my working B&S mower to my son after he moved into his house. Another friend had loaned me his Honda mower, so I had the Briggs and the Honda experiences fresh in my mind before purchasing the Huskie. BTW, the Honda is VERY overrated! You must start the mower and let it warm up before you can use it. It is very cold-natured, and if you don't let it warm up before using it, the engine will stall almost immediately. VERY peculiar for such an expensive mower.
As for the Huskie with the Kohler engine, I won't buy another one, and wish I hadn't bought this one. In addition to the starting problem, it has been very sensitive to fuel with ethanol in it (now, 100% of the gas stations in Texas have E10 fuel) and I just had to flush and clean the entire fuel and carb this weekend due to bad gas. Also, parts are harder to find for the Kohler small engine than a comparable B&S model.
With all of these issues, you may ask why did I buy it? Well, I knew Kohler has an incredibly good reputation for their engines used in generators and other large applications. I wanted to buy one more mower that would last as long as possible, without having to spend $600-900 for something like a Honda. And, I already have a Cub Cadet tractor with a Kohler Courage 22 engine that is virtually trouble-free. But, the Kohler small lawn mower engines are a totally different matter. To add insult to injury, I found out AFTER buying the mower that the Kohler engine is made in China.
So, if you seriously want a Husqvarna, get one with a Briggs & Stratton engine, preferrably with a primer bulb or manual choke. The Briggs engine has been improved so much over the last few years that there really isn't any good reason to spring for the extra money for a high-priced push mower. BTW, the dealer where I bought it now has completely dropped the mowers with Kohler engines. Regardless of the brand, from $200-$600 with all the bells and whistles, underneath is a Briggs engine.
Hope this helps. Good luck!
