Husqvarna RZ5424 Wire Harness Replacement. Strange Solenoid Connector.
deshazo19
  • / Husqvarna RZ5424 Wire Harness Replacement. Strange Solenoid Connector.
I'm installing a new wire harness on my RZ5424. I've been making my way through with no issues until I got to the solenoid. The old red wire ring terminal connection that stacks on the hot battery connection is non existent on the new harness. Instead, there is a white plastic barrel type connection, and I can't figure out what I'm supposed to do with it. I've looked for ring terminal adapters that would connect, and I've even thought about snipping the wire and joining it with the old ring terminal. The black wire on the new harness has the ring terminal connection, but that wasn't hooked to anything on the old harness. Pictured is the old wire with the ring terminal, and the new wire with the white plastic connection. Any ideas? Thanks in advance.
