I have a Husqvarna riding mower with the Kohler Courage SV730 engine and it has recently had a few issues. It started backfiring and revving up and then the valve lash adjustment nut on the intake valve of one cylinder fell off. I reinstalled this and adjusted to spec. I assumed that this backing off was the cause of my problems but it is still acting up. The engine RPMs sound much higher than normal and it will start backfiring and popping if the engine isn't under any load such as when it is sitting still. Doing anything such as speeding up, slowing down, or engaging/disengaging the blade will pretty much guarantee a big backfire. Letting it sit and idle will cause lots of backfiring like a machine gun. It is very loud and we are talking loud to the point of needing to wear ear plugs. You get that concussion feeling through your chest such as when a you fire off a high powered rifle.
The muffler appears to be bulging and has ruptured at one of the seams from this. The muffler was also glowing red and shooting enough flames that it caught some dry grass on fire. There is also usually some run-on or dieseling when the engine is shut off.
Besides all this mess, the mower has more power than ever and seems to not bog down as easily as before but does seem to be consuming more gas than normal.
I have also been running synthetic oil since I have had this mower and there wasn't a spec of sludge under the valve covers. Everything was shiny and clean like in a new engine.
Any ideas on what has happened here and how to best correct the problem?
