I have a Husqvarna M ZT 52. The kill switch has caused me a problem ever since I got it. Whenver you go over a big bump, it would cut off. So I would have to get up and wiggle the connection. I tried to hot wire the switch, is located directly under the seat by connecting the 2 ends of the wires together, completing the circuit but it doesn't work. Finally the other day when I hit a big bump the engine cut off, I wiggled the switch, but it wouldn't start. So now it will not run at all. It is all related to the seat switch. Any ideas how to fix it or by pass it?
