Husqvarna mz5225
Baxterdeb
It was running fine and then it would go slow forward and stop the same backwards now it won’t move at all
gainestruk
Has to be something to do with belt, I've never seen both hydrostatic drives go out at same time, make sure spring isn't broken on idler pulley that keeps drive belt tight, or that the idler arm hasn't seized to frame.
