Export thread
Husqvarna lth 120 looking for headlight wire harness and age of my machine?
#1
A
awbooth
I have a Husqvarna LTH 120 lawn tractor. Serial number 110599C001133, ID # 954140106A, product #954-14-01-06. I'm looking for parts for my tractor. In specific I'm looking for the head light wire harness. In addition, can anyone help me find out the age of my tractor with the information I provided? Maybe someone knows more than I do about the machine and can share the good and bad about the lawn tractor. Thank you very much. Great forum.
Anthony
#2
BlazNT
BlazNT
The first two digits are the year 11 = 2011
The next two digits are the week 05 = 05 week of the year
January 23-29 2011
Here is your parts list. http://www.husqvarna.com/ddoc/HUSI/HUSI1999_USen/HUSI1999_USen_I9902049_.pdf
The part you need is no longer avalible.
#3
A
awbooth
This was extremely helpful.
Thank you for taking the time in educating me how old my tractor is.
Since the part is not available, would I be able to make my own socket, wire setup to make the headlights work?
Not sure why the tractor didn't come with the headlight wire harness in the first place?? It can't be so popular of an item to remove and resell unless it melted, got damaged etc.
In addition, do you have any information on the quality of this particular year, model Husqvarna?
Thanks again.
Anthony
#4
BlazNT
BlazNT
2 models built. One with headlights and one without. I know nothing about that model except I think Husqvarna makes a very good mower. It is a light weight tractor so no hauling. You can easily create a wiring harness. It is only 4 wires.
#5
A
awbooth
Do you think it will be strong enough to pull a tarp full of wet leaves?
#6
BlazNT
BlazNT
No more than 150lbs I think.
#7
A
awbooth
ok, thx again!
#8
A
awbooth
Well, new problem with machine I've just noticed.
At initial start-up of the tractor the 12 HP Briggs and Stratton motor SMOKES QUITE A BIT. It slowly goes away but is there a way to get rid of that smoke? Thanks
Anthony
#9
BlazNT
BlazNT
What color is the smoke? Picture is worth a thousand words.
#10
A
awbooth
White smoke, it doesn't fly out strong like the engine is over filled, however it smokes for about 30 seconds, than clears up. I guess the more I use it the quicker I'll find out how much I have to add to keep it full. I heard the Koehler motors are much better than the Briggs. I have the Briggs
#11
A
awbooth
Any thoughts on the initial white smoke?
