skipperjohn
- Mar 26, 2016
- 1
- 2
I have a three year old Husqvarna HU800AWD walk behind mower with a Honda GCV190 engine (manual start). It's been a good starting mower (usually first or second pull) up till this year. I've checked the spark plug and air filter, and filled it with fresh gas.
The only way I can get the mower to start when it hasn't been started recently is to take off the air cleaner, drip a few drops of gas into the carburetor, and replace the air filter. It will start on the first pull after doing that, and will run and restart just fine.
The engine has an auto choke. Is it possible that the choke is not working correctly in this engine, and if so, what is the fix?
Thanks,
John
Thanks,
John
