overheadstew
- Sep 11, 2014
- 1
- 1
Hello everyone-
I am new to this forum so bear with me. I have a husqvarna lawn mower that is giving me some engine problems. At the start of the season, my lawn mower would start, but would rev very slowly and had a hard time before it would die. I cleaned out the carb and it seemed to work well for a while. Then I noticed that the engine would start fine, but then it would surge and have a hard time finding a steady rev while I was cutting my grass. It got to the point where it wouldn't fill up the bag and struggled through thick grass.
After starting the lawn mower, I could press on the governor throttle arm and after a few pushes it seemed to run a more consistent rev. My governor arm on my honda engine has a small hole and a large hole. One day I moved the spring position to the larger hole and it revved fine and gave me no troubles. My question to everyone is- is this ok? Do I risk harm to the engine? Should I get a new spring and put it back back into the original position?
Thanks again- I know this a lot, but it has been killing me since this lawnmower is only 1 year old.
