Husqvarna 775 Ex rear wheel drive lawnmower
Johnjt10
Trying to change the belt on my 775 EX Husqvarna
I'm having trouble removing the belt from the guides.
I have removed the blade and the plastic housing around the blade
Is there a way to remove the pulley or remove the guides.
husqvarna
Did you ever figure it out? I'm having the same problem. Trying to remove the rear axle and having no luck...
