Husqvarna 125B runs great until I shut it off and restart, wont rev
Markie
I have a 5 yo Husqvarna 125B that starts on third pull every time. I can use it for 20-30 minutes with no problem. High end speed and acceleration is good, revs well. However, if I shut it down for several minutes and restart, the unit will start and idle but will not rev up. I can coax RPM up with the throttle but it labors and never runs like initial start up. Applying a little choke while running poorly doesn't help.
I tried fresh fuel and remixed to ensure 50:1. cleaned air filter, checked plug. any suggestions?
