What the unloader valve does is let the water circulate in a loop through the pump when you let off the guns trigger .. to prevent high pressure build-up which could damage the pump or people, it should NOT be adjusted, ( unless being replaced or repaired ) to try to increase the pressure from the nozzle, the NUMBER size,  of the different color nozzles determines the tip pressure which is best attained by the use of a nozzle chart and an inline pressure gauge .
Remove the gun from the hose coming from the pump see if water is flowing , if it is, gun MAY be plugged up, then remove hose from the pump, if no water out of outlet, the pump is in need of repair or replacement. also be sure garden hose to pump is not plugged, and check the filter screen at inlet of garden hose connection.
