Export thread
Huskee Wood Splitters
#1
A
AndyMan
Has anyone used a Huskee firewood splitter? They look like they would do a good job, but they also look pretty dangerous.
Right now I split all of my firewood by hand - mostly oak and maple, with a bit of apple and cherry.
#2
173abn
173abn
AndyMan,are those the ones sold at T.S.C. ?would'nt mind having one.I just split 2 cords by hand.guess it's good exercise for a 60 yr. old. russ
#3
RobertBrown
RobertBrown
A friend of mine has one and he thinks it's the cats a$$. It seems pretty safe to me, doesn't move all that fast. As long as you keep your hand off the end of the log it's probably less dangerous than a mower
#4
D
Dannie
Have one,should have got one sooner.Any piece of equipment is as save as the user.
#5
A
AndyMan
I did see them at TSC. They had them in two different sizes. Are the different sizes for different sized logs, or for different hardness of wood?
#6
RobertBrown
RobertBrown
Get the big one
#7
173abn
173abn
It's like the old saying you get what you pay for .the larger one works faster ,has more splitting force,larger cylinder,bigger pump and motor.They also sell a verticle unit .Never used one so can't say which is better. russ
#8
M
Mean Machine
We gathered 5 cords this year. Usually I split it by hand a little at a time. We started a little later than usual, so I got behind on the splitting (which I love to do). I rented a splitter for a day and made quick work of the last cord.
#9
G
Green Girl
We use ten cords of wood to heat our home each winter. We absolutely could not live without our wood splitter! We got a good deal on ours from a neighbor who decided to upgrade his model.
#10
173abn
173abn
Green Girl,that's a lot of wood! Is wood your only heat source and what kind of wood do you burn? russ
#11
N
Natureboy
The Huskee units are fine splitters. The ones at TSC are vertical/horizontal units, and are heavy duty with a full beam and log cradle. They dropped their price on the 22 ton recently to $999.00. If your splitting 8 -12 face cord a year the 22 ton should be fine. For larger amounts, I think I would go bigger.
#12
Two-Stroke
Two-Stroke
I'll second that. I can't imagine using that much wood -- but I live in the South and am a huge fan of thermal underwear.:smile: I just light my first fire of the season last night and could have done without it.
#13
A
AndyMan
Holy Buckets, Green Girl! Do you keep your house extra warm, or are you short on insulation? :wink:
We go through 3-4 cords each winter. Our wood stove is in the basement, then we run the furnace fan to circulate the air through the house.
