I have a Stihl HS 72 Hedge Trimmer. I bought it used. The carb needed a rebuild, so I found a new carb for $20 and installed it. The trimmer may run fine today, but the next time the carb needs adjusting. Today, it won't start. What could be the problem? Why is it not consistant? I am thinking it is leaking air through the crankshift seals. Could this be the problem, or am I overlooking something else?
Thanks
Thanks
