Rickmo
Hi,
Apparently when I bought my HRXHMA lawn mower, I think the previous owner disconnected a wire to the solenoid. There is a yellow wire with an insulation over the metal connector that is hanging. The wire is yellow and there is a tab sticking out of the solenoid where I believe it should be connected. Can anyone with this lawnmower confirm?
Also the key broke off in the switch, but I was able to turn the switch to the “Start” position. I’ve tried to remove the key but to no avail. A new switch and key maybe the only choice here.
Thanks,
-Rick
Thanks,
-Rick
