PuHowie
- Mar 25, 2026
- 2
Hi all -
Working on an HRK217K5 where the mower will not shut down when using the throttle to engage the grounding kill switch. The actuator sticks and I'm trying to determine whether the spring (in the attached diagram) is the issue, or whether it's something else that folks have worked on before. I tested the kill switch, it works fine, but the linkage stops just a tad bit short of actuating the kill switch, which is kinda annoying to reach down and kill it. Any thoughts would be appreciated greatly.
