hrx2172vkaa with bent crankshaft
dante2
I hit a solid object the other day while mowing and bent the crankshaft, woodruff key, and tweaked the flywheel. I got a new flywheel and key before discovering the bent crankshaft today. I am very handy with my tools and very mechanically inclined, ( I own a 94 wrangler and no one but me works on it ) so my question is how difficult is a crankshaft swap? Which manual should I get to help with the tear down or is there a good video out there? This has been a very good mower for the last 4-5 years and it still has life left in it. Thank you for your help.
Crank swap on the GCV190 engine requires the block to be split apart; here's the basic idea (engine shown inverted):
A factory shop manual is nice to have; Honda sells paper copies ($34.95) via Amazon and eBay (free shipping)
Honda Power Equipment Shop Manuals on eBay
Honda Power Equipment Shop Manuals on Amazon
Bent cranks "can" be straightened, but it is art and could cost more than a good salvage unit. If you are a tinkerer you can experiment with a hydraulic press , dial indicator and V blocks.
Thank you robert@honda. Your book info helps as I wasn't sure which book to get. Looks pretty straight forward.
motoman I am going to get a new crank and call it good. I don't have access to a press and who's to say it
wouldn't break later anyway. Thank you for the help guys.
