HRT216 with drive problems
catbob
New member so thank you everyone. My Honda HRT216 with a 3 speed transmission has stopped propelling. Removed the transmission and everything seems to work when pulling back on the the clutch lever and rotating the pulley. I'm looking for away to be able to bench test this, I hope someone might be able to help. I have many new drive parts including belt, drive pulley, and new drive gears. Thanks again
Thanks for your reply, but I couldn't find any information on bench testing my transmission. I'm trying to troubleshoot my drive problem and thinking it might be my transmission just wanted to make sure. Going to change the clutch cable next just to make sure after reading that others have had trouble.
