Hi all, I've got a 2014 HRS216K5PKA, original single blade. I'd like to replace the blade with something better for mulching. I don't see a part number on Honda's website for their OEM mulching blade to fit this unit. Can I use blades for an HRR mower, instead of the HRS? Or is there an upgrade kit out there I should be looking for instead?
Also, the mower is noted as having ball bearings in the rear wheels. Are there ball bearing equipped front wheels I can add to this mower to make it a little easier to push?
