HRR216VXA not self propelling
rothomas
I have Honda HRR216 VXA mower that stopped self propelling. I replaced the belt and the transmission but no results. Any ideas as to what else I should check?
Briantii
Also check the pinion gears in the rear wheels. If the ratcheting key isn't moving then it won't go anywhere either.
enigma-2
Probably a silly question, but what's the condition of the engagement cable? Stretched too far? Adjusted properly?
