HRR2169VKA Missing Strip of Grass Near Middle of Deck
Chris2237
Hi, I bought a Honda self-propelled mower a few years ago and it has always had a problem with missing a small strip of grass near the center of the deck. It seems to be getting more pronounced, and I'm getting rather annoyed, so I figured I'd turn to a forum and find out if it is fixable. Any thoughts on this are appreciated.
The mower is model HRR2169VKA. Missing strip is just to the right of center, if standing behind, facing toward the handle like you're operating. Blades may be a little dull, but are undamaged.
Thanks in advance
I would like to also add that I cleaned the deck to remove buildup and the problem is persistent regardless of the grass height, mulching, or bagging. The height adjustment is on the second to last before max height.
Maybe the mower ground speed is too high?
Did you try mowing at a slower ground speed by reducing pressure on the smart drive?
I am wondering how is that possible when the blade is rotating at full speed when mowing.
The blade should cut through all 4 sectors of the mower deck and not leave an uncut strip.
Can you post a pic of the underside of the deck?
I have tried varying the speed at which I progress. No difference.
An interesting observation is that if I'm mowing on a very slight grade, with the right side of the mower on the uphill side, it misses grass. When I come back the other direction, it seems to cut everything fine.
Just for kicks, try sharpening the blades.
I just sharpened my Honda HRB 215 mulching blades using a disc grinder.
It cuts really nice.
