Hello, new here on the forum.
I salvaged my HRM215K1SDA a few years back from someone in the neighborhood who couldn't get it started. I basically sprayed some carb cleaner in the carb to nurse it into running, probably some bit of debris in the carb finally dislodged. Also the transmission had (still has) a broken gear - so I just removed it. Recently I noticed fuel in the crankcase, so apparently fuel leaking past the float needle. I am wondering if this generally means replacing the needle, or if just needs a cleaning. I'm not sure what engine this model has (GXV140??). Can you suggest a reasonable website for replacement parts?
Thank you!
Thank you!
