silverturbo
- Aug 21, 2013
- 1
- 4
I am the original owner of this mower purchased back in 1995/6. It has ran like a champ until recently. I had trouble running it unless on choke which was corrected with a thorough cleaning a few years back. However it has restarted that issue (I cleaned it again last night but to little avail). I have orders some gaskets for now.
The other main issue is the roto-stop system has had issues that I assume are due to wear. It has squealed when spinning up the blade some during engagement, but now I can tell (hear) the blade is spinning slowly while the engine is a steady high speed. I have read several threads on here discussing similar situations, recalls, etc. I assume the "driven disk" part in the schematic contains the friction elements(?)
I have ordered the Honda manual which should help. Are there any other tips before I start to take it apart?
The serial # is: MZBB-6438605
Thank you.
Thank you.
