hrlp loose white wire after starter replacement.
joboy1937
I have a super min iz with a 25 hp Kawasaki I just replaced the starter but I find a loose white wire with a green stripe .it is a fairly heavy gauge wire that originates somewhere under the carb and the other end is loose. i'm afraid that it plugs in somewhere around the top of the starter . the schematics do not show a white wire with green stripe. anybody know where this thing may terminate?
Only wire with white/green comes from the carb solenoid and goes to (e) on the key switch...!
