Hrd536 drive problem
Dlongson
I have a problem with the drive in that the small roller (rh side looking from the back) is working fine but the left hand side has stopped working. Is this an easy fix or does it needs major work?
When you say "small roller" are you talking about the drive wheel on the left side, or something else? (Does your Honda HRD 536 have a stripping kit installed (didn't see a small roller in the owners manual).
Is it frozen in both forward and reverse?
