Highmaster2
Hi,
Have an HR215SXA Master Series that I got used about 8 or 9 years ago. While the transmission seems to be working perfectly, I know that at some point it would probably be prudent to check/top off/replace the gear lube in the transmission (all 6.7 ounces of it). Have no idea if it's ever been changed or not.
I apologize if I missed something in the shop manual, but is there any way to get to the lube other than breaking open the transmission case?
Thanks!
Thanks!
