wfsway
- Jul 10, 2016
- 31
I understand, the pins #54 are the same dimensions, anyway I have used proper diameter brush (cheap Harbor Tool) approximately 5-6mm to just clear shiny metal of the hole. I cannot Imagine it being beyond interference fit ? The Honda shop manual (attached) does not detail any special treatment. I would try putting the pin and shaft in freezer to contract metal, then graphite or oil and carefully tapping into place.
